tarnold's avatar
tarnold
Water heater pop off valve
Anything special about a suburban pop off at twice the price as any other common pop off, assuming same 150psi 210 degree ?
  • Hondavalk wrote:
    If you have lost the air pocket in your WH the valve will drip because as the water heats up it will expand. It needs the air pocket for expansion.
    Small expansion tank works as a permanent solution and no more messing with the T&P valve.
  • I just did this a few month's ago. Here's what I bought:
    https://www.homedepot.com/p/Cash-Acme-3-4-in-Bronze-NCLX-Temperature-and-Pressure-Relief-Valve-with-1-1-4-in-Shank-MNPT-Inlet-x-FNPT-Outlet-23576-0150/203164746
    The one I removed, which was the original, was the identical Cash-Acme valve.
  • If you have lost the air pocket in your WH the valve will drip because as the water heats up it will expand. It needs the air pocket for expansion.
  • Dick_B wrote:
    Don't know. Never had to change one. Heard too many times that they don't reseat after testing so we don't test.
    I fought with a dripping valve for years. Then I quit messing with the valve and now it drips no more.
  • T&P Relief Valve is a standard 3/4" valve with 4" probe 210*F/150 psi
    Any hardware store
  • wa8yxm's avatar
    wa8yxm
    If it id 1/2 inch IPT threads (iron pipe thread) as the other responder said any hardware. I have spare that size myself. but any hardware Nothing special.
  • You do not need to buy a Suburban releif valve. Most hardware stores have the 1/2 inch valve with the same specifications.
    Verify pipe size! It could be 3/4 inch
    Amazon
  • Don't know. Never had to change one. Heard too many times that they don't reseat after testing so we don't test.
