h2guy
Jul 31, 2013Explorer
liveneasy wrote:
Typical home water heater relief valves are 3/4", while most RV water heaters use a 1/2" valve. The 1/2" valves are generally not available from Lowes, Home Depot or other chain stores, but may be found at plumbing supply stores.
If this is true, (haven't checked mine), why not just install a 3/4 to 1/2 inch reducer and go with the valve that is always readily available????
