Water Heater Question
diftw
We have a 2016 Grand Design Reflection 337 with an Atwood Gas/Electric water heater. It is still heating the water but the temperature is noticeably cooler than in the past. Is there something I need to replace? Thank you.
Dave and Anne
2016 Grand Design 337RLS
2015 Ford F350 XLT 6.7l 4x4
Reese Elite 18K Hitch
Rotochocks
Rota Flex by Trail Air Pin Box
Barker 4-wheel 25 gallon tote
Nights Camped in 2009 - 33
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
7 REPLIES 7
wa8yxm
Atwood it should not matter if on gas or electric or both.
What does matter?
Three things usually possibly 4
One: Bypass valves. are they all fully in the USE position?
Two: "Dog Shower" Actually the outdoor shower used to wash up after a sewer dump/hose activity... I have fixed a few by mentioning the cut off valve in the head stops water flow. but allows cold water to cross over to the hot lines if both hot and cold valves are open.. Optional: the main shower may have a cut off on the head as well same effect. (that's the #4)
3: how do you put 10 gallons of hot water into a six gallon hat?
Easy, heat the water to like 180 then use a thermostatic mixing valve to blend in cold down to 120.. and if you have that kind of water heater that valve may need attention.
diftw
Thank you Old-Biscuit. I checked the bypass and sure enough it wasn’t completely open. Appreciate the help!!
Dave and Anne
Rotochocks
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
Old-Biscuit
2016 Atwood gas/electric uses ONE set of t-stat/eco for temp control on electric or gas
T-stat s fix temp to open at 140*F
If wire connections are loose on the t-stat it could not allow full temp heating
If BYPASS valve (backside of water heater connects cold to hot) is open/cracked open/leaking thru cold will dilute hot right as it leaves WH Tank
If shower (outside/inside) are turned off via button on handle then hot/cold mix inside the shower faucet....luke warm water in hot water system
diftw
I tried both but the outcome was the same. We’ve owned the rig since it was new so we know how hot the water used to get. Seems like some sort of a temperature regulator issue but not sure how to correct. There is a type of a circuit board on the upper-right side of the unit when you drop the door outside. I don’t think I can post a photo here.
Dave and Anne
Rotochocks
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
Dusty_R
If I remember right. If you forget to close the bypass valve, that you opened last fall to drain the tank, then the water will circulate and not heat all the way.
valhalla360
Nomad III
Nomad III
How long did you let it heat for before trying the water?
And as mentioned, are you use gas or electric (or both) for heating the water?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Dick_B
How are you heating the water? Electric or gas?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
