Bowhunter61's avatar
Bowhunter61
Water Heater replacement
Posted this in the toyhauler section but thought I would post here also to get some ideas
Anyone replaced a water heater in a Fuzion 302 or comparable? Wondering where I will have to access the water lines at? Thinking it is behind the panel in the basement area where the pump is located.
Unit is down in TN on my land in the pole building. Anticipating I am going to have to replace it because I screwed up and never drained the tank before the winter. Winterized all the rest but then left without draining the water heater (long story).
Usually not too cold down there but they had a good 2 weeks of cold weather in western TN.
Thinking of going tankless anyways.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
