Ormrod
Jul 16, 2013Explorer
Water heater won't light
Hi,
We recently purchased a new 2012 model Puma 298-FQU. It has a Suburban water heater that runs on propane only (no electric element) and I can't seem to get it working... When we got the unit from the dealer, they didn't go through the water heater because they hadn't filled it with water.
So when we got it, I filled it with water... I made sure the valves to the hot water tank were all opened and the hot water tank filled up. I made sure the propane was on (my stove and fridge were working). I made sure the battery had charge because all of the lights/radio/water pump/etc worked. However, when I turn the hot water switch on (behind the kitchen sink), outside the ingiter doesn't click and the propane doesn't fire. The switch then stays lit with a red light that never goes off. There is also a small light inbetween the hot water switch and the water pump switch, this never turns on. I can shut it off and turn it back on again, but it always does the same process.
Here is a picture of what my model looks like (I don't have a picture of mine right now, I'm at work)
Any ideas what I can look at, or some things I may be able to test?
Thanks!
Thanks!
