- Garry_GayleExplorerTry your question on the Yahoo Carriage Forum, you will get answers from actual owners.
My 04 Cameo had the water pump in a side compartment, look for the drain hoses under the bottom, water pump should be close. - Old-BiscuitExplorer IIIWater heater is in kitchen cabinet between the 2 slideouts.......check in that area for water pump
- DrewEExplorer IICan't you locate it by sound? Or maybe the issue is that it doesn't turn on....
Typically the pump is near the fresh water tank, and often hidden under or behind something with a removable or somewhat removable panel for "access". Mine (on a completely different RV) is under the bed, next to the water tank, and it's necessary to remove the mattress and unscrew the deck of the bed from its framework to get at them...at which point the access is actually pretty decent.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
