โJan-09-2022 08:25 AM
โJan-09-2022 09:45 AM
Thermoguy wrote:
I am unfamiliar with your rig, but if you are connected to city water, turn your pump off. You only use your pump when you are not connected and using your fresh water tank. By hooking to city water, you bypass your pump and water tank.
โJan-09-2022 09:44 AM
โJan-09-2022 09:26 AM
โJan-09-2022 09:21 AM
dougrainer wrote:
The most common cause of this type problem is, you have your City Water tank fill valve OPEN. This will cause the pump to continually recycle the water. I also assume it will turn OFF when requested to do so? From the Pump On/Off switch?. Now, if you are connected to City Water and that valve is left open, your fresh tank will overflow. You are new to the forum. ALWAYS, list Year/Make/Model/Chassis of RV when posting. Or put this info in your profile. Doug
โJan-09-2022 08:45 AM
Bud
USAF Retired
Pace Arrow
โJan-09-2022 08:42 AM
โJan-09-2022 08:40 AM
