โApr-15-2014 05:23 PM
โApr-16-2014 09:59 PM
Old-Biscuit wrote:
The backflush should be done every 3 months of use and whenever you have drained it to fluff resins bed. Gets rid of channeling and compacted resins. Just couple minutes will do.
So if drained..backflush couple minutes then place it in service.
Old-Biscuit wrote:
If just removed from service but not drained....just do the service flush (which means flush in the direction of the service flow) for a couple minutes prior to placing back in service.
โApr-16-2014 08:20 PM
โApr-16-2014 06:47 PM
Old-Biscuit wrote:
When it is hooked up to your rig and on city water and you are filling a large pot, filling the sink, taking a shower.........flow will be as much as can flow thru canister.
It works with full flow. Don't have to limit it or use it/let it stand/use it etc.
The resin reacts with the calcium/magnesium in the water instantaneously.
Old-Biscuit wrote:
Draining for travel/storage.
Pick up a double female garden hose connector because the resins can get packed when canister is empty.
Hook up a hose to water supply then to canister 'outlet' with connector so you can backflush/fluff the resins....full flow for couple minutes.
Then place it in service.
โApr-15-2014 10:54 PM
โApr-15-2014 06:22 PM
dbbls wrote:
I would address these questions to "On the Go" water softener manufacturer.
โApr-15-2014 06:11 PM
