da_bees
May 29, 2013Explorer
Not realy unusual and considering square inch surface of tank bottom,probably nessary to prevent pulling sediment. It will be a real problem come time to winterize. Have to pour in over 10 gallons of anti-freeze before pump picks it up.:M
Unless you have a water heater bypass. :B In which case you can winterize with 2 gallons of anti-freeze. Check it out and install a bypass if not already equiped with one.
