Chuckf1's avatar
Chuckf1
Ways to clean ceiling
our 10 year old motorhome is showing its age and we want to brighten ut up a bit. We have grunge on ceiling from cooking and wish to remove it without causing the ceiling material to pull down or droop or discolor much.
Thanks in advance.
  • JoeH's avatar
    JoeH
    Oxyclean laundry stain remover works great--- spray it on, let it sit for 5-10 minutes, blot it up with e clean white rag.
  • I used Awesome Orange on an older 5th I had at one time...cleaned the ceiling and the walls. Then went ahead and painted them a semi-gloss white.
  • Moved to Tech Issues from Dinghy Towing
    Admin
    RV.net
  • Can you describe what your ceiling material is or share a photo? Different things work for different materials IME.
  • I'd try the Mr. Clean Magic Eraser pads in a small area first.
Having RV issues? Connect with others who have been in your shoes.24,234 PostsLatest Activity: Apr 14, 2025
