BFL13
Sep 12, 2015Explorer II
Don't forget that 13.2 is 'as seen' at the converter, so if there is voltage drop on long thin wire from battery to converter, the battery may be under 13.2, but the converter will see higher than that.
So part of the deal is to have low resistance between battery and WFCO as well as the other business wrt charging rate and SOC.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
