Dayle1's avatar
Dayle1
Aug 15, 2015
WF8950 door latch
The door on my WICO WF8950 converter failed on our last trip. The tiny latch has broken internally and will not hold in the 'latched' position. Anyone have a good solution short of getting a replacement door? Thanks in advance.
  • Thanks for all the help. I was unsuccessful finding a replacement door. But suprizingly, I found a source thru Amazon for just the tiny latch, less than $3, got the last one they had.
  • Can,t find name of person at WFCO, but they sent me some replacements when I emailed them about the same problem. I'm not home but will look and post if I can find it later this evening.
    You might try to Google WFCO for an email address.
    http://wfcoelectronics.com/contact/
  • You might be able to epoxy a magnetic catch as-sembly into the enclosure. It would probably be cheaper than a new door. JMO
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
