Timeking
Jun 25, 2021Explorer
Parasitic draw on my 2018 Rockwood 2606WS TT is 0.33 amps, which is apparently sufficient to keep the WFCO at 13.6V. Yes, I could turn off CO and propane detectors ... risking not turning them back on. Bad idea that.
So the question is "does any converter drop to 13.2 over a 0.33A parasitic draw"? I'm thinking not.
Although posts above say 13.6 not a problem, but 13.6 did burn up a battery when I didn't check the water level for 3 months. At 13.6 I can see slow out-gassing going on in all the cells. It would be nice if there was a button I could press and the voltage would drop to 13.2, overriding all this 'automatic' techno babble that doesn't actually work on modern RVs.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
