Timeking
Jun 25, 2021Explorer
Here is what WFCO says (and like howardwheeler above, no 13.2):
"First, if your battery burned up just supplying 13.6 vdc to it, there was a problem with it such as a bad cell. A good battery should not have an issue with a constant 13.6 volts being supplied to it.
With regard to the Float mode, if the load current being supplied from the converter is 5 Amps or less for 44 hours, then the converter will drop the output voltage to 13.2 vdc. Once in Float mode, any rise in output current draw above the 5 Amp level will cause the converter to go back to Absorption mode (13.6 vdc.). To go back into float mode again, the process would start over.
Thanks and regards -
Ted Krueger"
Ted Krueger"
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
