noteven
Dec 14, 2019Explorer III
ORbiker wrote:noteven wrote:
My camper has a 55amp WFCO power center. I see a module on their website to change it over for using with LiFe04 batteries. I expect the battery monitoring system in the “lead acid replacement” type lithium batteries will protect them from the charging sources (WFCO / Zamp solar) going crazy and wrecking them.
Has anyone got any experience using the WFCO lithium module?
Get rid of the 55amp WFCO power center. POS
LinkConversion table.
Thanks ORbiker - the linked table is the info I need. I’ve been happy with the PD unitsin my other rigs. I may change the whole unit out and add some more solar and stay with flooded or agm so as not to have to deal with protecting lithium batteries from cold.
Edit - looking at the PD4655 models at Best Converter PD has the 4655LV model which can be changed from flooded/agm mode to lithium charging- this would be ideal.
