What are the best batteries and where to buy them?
mtbg308
I'm trying to bring back to life an old 40ft class A with a Cummings diesel motor that's been sitting for 5+ years. Need batteries all around. What are the best batteries for for engine start, and for deep cycle, and where do folks usually get them if they're looking to save a few bucks?
Hope I posted in the right place. Thanks!
17 REPLIES 17
allen8106
For house batteries I recommend Crown.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
pianotuna
Nomad III
Nomad III
Some situations make 12 volt preferably to 6 volt. Cell failure is NOT one of them--and in fact favors six volt jars.
2oldman wrote:
Somebody always has to bring up the 'battery going bad' argument with 6v. The chances of an otherwise healthy and not old battery going bad are remote. Basing a battery decision on that extremely unlikely event is not a good decision.
Regards, Don
RJsfishin
Quote:
(Indeed, a pair of 6V batteries is just a single 12V battery that happens to be in two sections that are less inconvenient to manipulate than a single equivalent battery would be.)
Would you please explain that statement ?
A 6v weighs about 65 lbs
An equivalent 12v weighs 130 lbs.
Please explain how that 130 lb battery is more convenient to manipulate.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
dave17352
Chris Bryant wrote:
Golf car dealerships will often have the best prices on the standard Trojan T105.
I found this to be true in Lincoln, Ne. Very good prices on the
Trojans.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Chris_Bryant
-- Chris Bryant
2oldman
DrewE
Dusty R wrote:
I like Deka also.
I understand that they make batteries for NAPA.
Two six volt in series might be better, but if you are in the middle of nowhere and one six goes bad, you are up the creek. But if you have two 12 volts in parallel and one goes bad, just disconnect it. You will only have 1/2 battery power, but you are not dead in the water.
Dusty
If one battery in parallel goes out, it's not unheard of for it to damage the other one too. Golf cart batteries are quite robust and rarely die suddenly; they have thicker plates than dual-purpose 12V batteries that are commonly used for RVs.
But yes, if one dies, you are in trouble, just as you would be if you had a single 12V battery that went bad. (Indeed, a pair of 6V batteries is just a single 12V battery that happens to be in two sections that are less inconvenient to manipulate than a single equivalent battery would be.)
I prefer the golf cart batteries myself. Naturally, others are welcome to have different opinions and preferences.
pianotuna
Nomad III
Nomad III
Hi,
If price is no object then move to Carbon Foam batteries for the house. They can be discharged to 80% and do not require charging to 100% every cycle.
Regards, Don
Dusty_R
I like Deka also.
Dusty
wa8yxm
Sam's is often cheaper than Costco and often has Golf Car batteries in stock.
I have DEKA in my RV.. By the time I paid for a Sam's membership,, They were about the same price... So far I'm pleased.
OH, Deka are made in the USA.
mtbg308
Thanks all. I'm going to take the golf cart advise and check out Costco, as well as look up the recommended starting battery.
Have a fabulous and safe new year. You folks are Awesome!!!
Mike G.
BFL13
A "token" house battery if that is all that you need, still has to be able to start your built-in generator though. I don't know what that takes.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MrWizard
Moderator
Moderator
for starting MY Cumins
i use AutoZone gold tops, (2) of them, gold tops have a 3yr free exhange, and 4yrs more of prorate, and plenty of cranking power
for house, i have run various batteries over the years, and settled on 12 AGM telco/server batteries giving me the best life,
Golf cart 6v pairs, work very well for most users
I can explain it to you.
1997 F53 Bounder 36s
RJsfishin
Bang for buck, a couple 6v golf cart from Costco.
Starting,......what ever the diesel requires, and probably from the same place....or WM
Rich
