bigrigfixer's avatar
bigrigfixer
What are these wires for?
I have a question about how and why my batteries are connected the way they are.
I had the battery covers off, and was gonna pull the batteries out to test fit a toolbox on the a-frame but alas, it won't fit between the propane tanks and the front of the trailer.
Anyway, there's the negative from the first 6 volt, then a jumper to the second 6 volt, then the positive, making 12 volts. Makes sense so far, right?
There was also a pair of 10 gauge wires with #10 studs jammed under the 3/8" lugs of the jumper cable. And it was red to the positive off the first battery and white to the negative of the second battery. I don't know what it's for, but as I see it, there's zero potential there. I'll post a pic of it for clarification shortly.
Any ideas?
