theoldwizard1
Jan 10, 2017Explorer II
Just to add a couple of things
If you are assuming that you vehicle alternator is going to recharge your house bank while driving to your next campsite you may be disappointed. Most "modern" (>2000) vehicle charging systems will NOT put out enough voltage (>14V) to recharge your house bank.
There are a few DC-DC battery chargers that will step up low voltage (10VDC) to the require voltage.
- Use "marine" grade wire. It will not corrode
- Use "marine" (dual wall) on all crimps
- If you really need that many connection point on the vehicle 12V "bus" consider installing a "bus bar"
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
