wa8yxm
Jan 11, 2017Explorer III
What determins wire size is max amp load
What improves charging time
Larger wire will pass more current with less voltage drop
A DIRECT connection from the converter to the battery bypassing those 14 connections you mentioned.. That will help even more.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
