What size cable betwee 6V batteries?
Vintage465
What size cable should I put between the 6v batteries on my rig? Meaning between the positive and the negative?
Thanks,
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
20 REPLIES 20
time2roll
What if he has a 100 amp WFCO converter? Or 1000 watt inverter?
I agree with same size as largest cable on other terminals.
Cydog15
2oldman wrote:
that depends on the size of the cables feeding the RV.
No it doesn't. It's going 6 inches and voltage drop is practically nothing. 8 ga is plenty. I noticed my Progressive Dynamics 4600 series uses 8 ga to the fuse board but to the batteries is what matters. Bigger the better on a longer run.
CloudDriver
The same size as the positive and negative cables going to the RV. All three will carry the same amperage.
When I switched from two 12 volt batteries in parallel to two 6 volt batteries in series, I used one of the two short cables that had previously connected the two 12 volt batteries together.
2003 Winnebago Minnie 24F - Ford E-450๐Ÿ™‚
hedge
If you have an inverter you'd want it at least as large as the wires going to the inverter. I have 2 gauge between my batteries.
2017 F350 Platinum DRW
2013 Adventurer 89RB
B_O__Plenty
I used some #4 that I cut from a pair of jumper cables. Made my own lengths and the cost was much lower than buying them.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
2oldman
