โOct-14-2016 08:00 PM
โOct-16-2016 02:36 AM
โOct-15-2016 10:03 PM
Huntindog wrote:
I use the stuff sold at the auto parts store.
โOct-15-2016 08:33 PM
โOct-15-2016 08:02 PM
DrewE wrote:Mine were all copper. I used copper terminals as well. Just used it for thr short cables that connect the 6 volt batteries to each other. The rest are 2 gauge that I already had.B.O. Plenty wrote:
I used some #4 that I cut from a pair of jumper cables. Made my own lengths and the cost was much lower than buying them.
B.O.
If it's working well and safely for you, I don't want to suggest you change stuff.
But, in general, it's worth noting that nearly all jumper cables these days are made using copper clad aluminum wire, and so the current carrying capacity is not equal to that of the same gauge of copper wire.
โOct-15-2016 12:50 PM
BFL13 wrote:Voltage drop won't be an issue for a length of less than 12 inches.
All these wire gauge questions come to the same thing:
A. ampacity so you can do the amps at all
B. voltage drop so you can operate your equipment
Lots of people seem to read the ampacity tables to get the safe size of wire, and miss the point about such things as staying above the inverter alarm voltage, converter voltage as seen at the battery, and solar controller set points
Once you have the safe ampacity solved then the lesson learned is often to go bigger than that to address the voltage drop issue.
โOct-15-2016 09:20 AM
โOct-15-2016 07:24 AM
B.O.
โOct-15-2016 07:09 AM
โOct-15-2016 06:48 AM
B.O.
โOct-15-2016 04:08 AM
โOct-15-2016 03:40 AM
โOct-15-2016 12:24 AM
pianotuna wrote:
The same size or larger than the cables that feed the RV or any inverter.
โOct-14-2016 11:12 PM
โOct-14-2016 09:19 PM
