What Solar Panel Mounts?
allen8106
As I continue down my path of adding solar to my 5ver I bought 4 used 130 watt Kyocera panels today. I would be interested in hearing about mounting systems you have used with success on your RV. I have a 2010 Jayco 5ver with the typical 3/8" plywood roof.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
20 REPLIES 20
westend
A lot of guys don't know this but a screw fastened through Eternabond tapes seals itself as it is turned through the tape. If you use an electric tool (impact driver, drill) to turn the fastener in fast, the material of the tape will even encapsulate the head of the screw. There's a video on the Eternabond website showing this feature.
'03 F-250 4x4 CC
Strabo
Thanks so much for the ideas, I wondered what was best.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
Joel_T
I mounted AMSolars taped feet with well nuts and laid eternabond over that. It can't leak, I can tilt either way and the panels aren't going anywhere.
Lance 15.5 2285 w/rockers Ram2500 4x4 CC 6.4 hemi 6spd w/3.71
Two 6v Crown 260ah / TM-2030 monitor / SC-2030 controller / Two 160w panels / EMSHW30C surge protector / 2000w inverter / TST507 TPMS
unbob
Ed_Gee wrote:
More and more people are using 3M double sided tape instead, though. This precludes having any holes at all in the roof. I have never heard of a solar panel mount failure in using double sided tape, either.
I had mine attached with 3M VHB tape - and it failed. But for a very good reason - F5 tornado with winds clocked at 210mph. Everything on the roof blew away - PV panels, vents, everything. The only reason the entire rig didn't blow away was that the wind was hitting from the front - if side-wind, it would have tipped-over and rolled until totally destroyed. I was very lucky to have survived that one!
So, yes, 3M VHB is great stuff - but it can and will fail given the worst conditions.
Ed_Gee
AM Solar uses 3M VHB 4950 tape for Solar panel mounts.
AM Solar panel tape
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
CA_Traveler
Ed_Gee wrote:
AM Solar also points out that they have been using double sided tape for panel mounts since the mid 90's and have never lost a panel. They also use a nice custom cut stainless steel bracket instead of aluminum..... much stronger and more versatile, too.
There are a variety of tapes so which one or ones? How do they clean and prepare the roof?
I used 3M 4941 VHB on painted aluminum and #10 SS screws and Dicor. Cleaned with alcohol.
2014 Grand Cherokee Overland
Bob
Ed_Gee
Scion xA toad
hedge
If you read the instructions on Am-solar's page they say they say they include screws with their mounts for rubber roofs, they use 'tape-only' on fibreglass roofs.
AM Solar Mounts
2017 F350 Platinum DRW
2013 Adventurer 89RB
nkgunner
AM solar uses 3M tape for their mounts with no screws..I plan on using that method of mounting my panels..
http://amsolar.com/
RJsfishin
Never fear,.....photo above shows the pre dry install. After all holes drilled and SS screw loosely installed, then brackets were removed, debris swept away, and Dicor installed. Takes more time, but a clean install.
Rich
hypoxia
I just use galvanized L shaped Strong Ties from Lowes, Home Depot or wherever.
Strong Tie
Jim
2007 Monaco Signature Noble III ISX 600HP
Johnny_G1
ktmrfs wrote:
RJsfishin wrote:
Its as simple as this....and tilted to either side
nice install, but in Oregon, well for anywhere for that matter, I'd be concerned about the exposed screw heads. from experience they are NOT watertight, so it is highly likely that water will get underneath.
Personally I put dicor or similar on the screw heads and all the way around the bottom of the bracket.
Dicor under the bracket before you tighten them down is sufficent,it will squeeze under the bracket and around the screws and will be water tight,installed 100s that way and never seen one leak yet and you need very little Dicor.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 2001 32.5' Okanogan 5th wheel, new to us after 5 yrs with the 28' Travel Aire. Lots of fun.
ktmrfs
2011 Keystone Outback 295RE
westend
Aluminum angle pieces are de rigueur for mounting panels. Most guys use two angle pieces in each location, one attached to panel and one attached to RV roof. This allows for easier removal and installation. The "Z bracket" is an alternative. Some of the better installations I've seen use aluminum struts and the modules are attached to the struts.
If attaching hardware into 3/8" plywood, it's a good idea to fasten through plywood into a roof truss, if possible. Toggle bolts also work but you'll have bigger holes and more work to use them. Inserts are another alternative.
FWIW, I have a bigger 235 module and a 4-way tilting mechanism on my aluminum roof. Besides the sealants, it is attached with 3 fasteners through 2 X "U" channel, each fastener through the roof and into a truss.
The examples of member installations that CA Traveller is kind enough to maintain a list of, pretty much cover the different types of installations.
'03 F-250 4x4 CC
