fj12ryder
Oct 14, 2014Explorer III
ScottG wrote:Would you please explain that statement? You may cause a grease leakage by improper greasing of an EZ Lube system, but how will "loading up the brake shoes with grease" make them run hot?
(snip)
Or, some one is utilizing the EZ lube system and loading up the brake shoes with grease which makes them run increasingly hot .
If anything it will keep them cool by reducing friction when you try to use them. :)
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 16, 2025
