โMar-31-2018 12:19 PM
โApr-02-2018 12:11 AM
โApr-01-2018 02:40 PM
marcsbigfoot20b27 wrote:
Double nutting the end of a bolt is near unbeatable.
โApr-01-2018 12:31 PM
โApr-01-2018 11:23 AM
โApr-01-2018 10:55 AM
Lynnmor wrote:agesilaus wrote:Lynnmor wrote:
If you have the two piece Ford lugnuts, they are to be lubricated with a drop of oil between the two parts. I doubt that ever happens on most.
That's the first time I've heard that. Maybe some day I'll RTFM
Here is a copy and paste from my manual:
On all two-piece flat wheel nuts,
apply one drop of motor oil between
the flat washer and the nut.
โApr-01-2018 09:56 AM
โMar-31-2018 07:27 PM
MEXICOWANDERER wrote:
Ramp-Lock Lock Washers
The principle is simple
Tightening the fastener the washer halves go "click-click-click" as they revolve against one another.
Trying to back off the fastener, special hardened teeth on the underside of the washer bites into the parent metal. The complete washer does not spin.
The washer has to separate the washer halves.
Only there is a ramp on both sides of the washer faces.
And the ramp is of a much steeper angle than the nut or bolt thread angle. Where one turn of a washerless fastener may allow a fastener to rise 1/16" inch, the ramp lock washer has be forced 1/8".
In short, they do not back off accidentally, ever
And they need no heat like Loc Tite RED does to loosen
When I build an extremely high amp switch board this is what I use.
Or high amperage alternators. The through-case bolts.
โMar-31-2018 05:17 PM
โMar-31-2018 05:15 PM
โMar-31-2018 04:01 PM
โMar-31-2018 03:48 PM
โMar-31-2018 01:13 PM
โMar-31-2018 12:25 PM
