Quint_Da_Man's avatar
Quint_Da_Man
Apr 21, 2020
Whirlpool Ice Maker Problems
I have a 2020 Thor Quantum WS31 class C with a Whirlpool commercial refrigerator and ice maker.
I winterized the ice maker by jumping terminals L and V on the ice maker which pumps water out until I saw antifreeze start to flow out.
Now when I attempted to clean out the lines I connected city water and jumped the same terminals filling the ice tray with antifreeze attempting to let it flow until it was running clear. After filling the ice tray about 4 times the unit stopped working and now it does not make ice. It cycles thru the ice making cycle but it is not pumping any water into the ice maker. I fear I burnt out whatever the water mechanism is.
Anybody have any idea what maybe happening?
  • wnjj's avatar
    wnjj
    If you manual method no longer works it sure seems likely to be the valve itself, but that’s just a wild guess on my part.
  • Traver8 wrote:
    The icemaker just activates a valve on the water supply, often found on the lower rear of the fridge. I must also ask if you have the water on - either city water or the water pump?
    Sounds like either the water supply is off or the valve has failed, less likely is a failure of the contacts in the icemaker itself.
    The basic icemaker should be easily replaceable and not too expensive online. Usually only a couple of mounting screws and the wiring connector.
    Hope this helps.
    Terry
    Thanks for your reply
    Yes water is definitely on lol I fill 4 ice trays full of water trying to get a clear flow before it failed.
    So if it's the valve that is probably not a good thing it sounds like the fridge will have to be pulled to gain access. Any idea on how I can isolate whether is the valve or the valve switch on the ice maker?
  • I don't know how long you worked on it but it takes 10 - 20 hours for the ice maker to get cold enough to cycle (ask for water) and dump ice.
  • The icemaker just activates a valve on the water supply, often found on the lower rear of the fridge. I must also ask if you have the water on - either city water or the water pump?
    Hope this helps.
    Terry
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
