RVcrazy's avatar
RVcrazy
Whirlpool refrigerator 11.6
Do any of you have the 11.6 counter depth 24” refrigerator? We need to know the depth of the door at the hinge & also the depth in the center widest part. It would go near the stairs in our fifth wheel. Have you had any trouble with yours? We have a 10.1 that is no longer made & the large shelf in the door broke. It is between this & the Magic Chef 10.1 because of space. Thanks!
  • Gdetrailer wrote:
    Cummins12V98 wrote:
    Any residential refrigerator will have these VERY specific dimensions for each model. Click on "download dimension guide" and you will get the PDF.
    Nope.
    Not "ALL" residential fridges have that.
    Try again, look up APARTMENT SIZE fridges (10-13 CuFt)..
    I have a 10.1 CuFt Haier brand and no such dimension guide was available.
    I also have a 30 yr old 21 CuFt Sears fridge in my sticks and bricks and once again no dimensions diagram was with it or available..
    Perhaps as in your example with a much more expensive double French door design I can see that perhaps but not ALL fridge manufacturers give that level of detail.
    It is far, far better to simply go to a physical store and measure it for yourself..
    On edit..
    To make this easy for you HERE is a link to the manual for my 10 CuFt apartment size Haier residential fridge.. Perhaps you can point to the exact page that gives a drawing and dimensions as I must be blind and missed it out of 18 pages..
    Before we bought our Haier 10.1 cu ft fridge (different model) from Lowes, I found all the dimensions I needed, including the critical to us depth with the door open on their website listed under "Dimensions".
  • If it does not have specific dimensioning it's NOT worth buying, probably Chinese JUNK. 35 years in construction needing appliance dimensions for cabinets I have always had all the exact dimensions needed with drawings exactly as I posted above.
    Nope.
    On edit..
  • Any residential refrigerator will have these VERY specific dimensions for each model. Click on "download dimension guide" and you will get the PDF.
  • Best bet is to locate the fridge of interest in a physical store near to you and personally measure it for yourself..
    "PDFs" of the owners manuals are often pretty generic for home fridges and generally do not list all dimensions (only the max dimension if it is listed at all) and online places like Amazon list the shipping box dimensions..
    Magic Chef, GE, Haier and a few other brands in the 10 CuFt apartment size home fridges are made by the same manufacturer in China. You will notice when you open them and look inside the freezer and fridge on the back wall will have the same basic look. Some may even share the same interior shelving and if your current fridge is one of those you might be able to find a newer model with similar door parts and use the new fridge model to order parts.
