opnspaces's avatar
opnspaces
Navigator III
Oct 02, 2022
Why not jack trailer under the spring plates?
For years people have asked where to place the jack in order to jack up a travel trailer. And people always say do not put the jack under the spring pack. This has bothered me for years because it doesn't make sense to me. Now I'm not an engineer by any means. But could somebody please explain why under the spring pack is bad? I mean look at the pictures below. In an under slung axle the entire weight of the trailer looks to be on two very small u-bolts. Am I wrong? It seems that the u-bolts are holding the weight. If the thin u-bolts are holding the weight.and the spring is on a thin perch welded under the axle; How is jacking at that point going to be a problem?
And in a travel trailer with over slung axles putting a block, or even a floor jack under the axle seems like it would be okay. The axle tube is thick enough to hold the trailer in the air with the u-bolts on top. Are we saying the tube is thinner on the opposite side of the axle tube?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
