โOct-22-2019 06:44 PM
โOct-22-2019 09:54 PM
joelyn wrote:That might be the quickest or only way to get the poly cord back in.
So are u saying I would have to take the entire awning off and then rewind it and remount??? YIKES..
โOct-22-2019 09:47 PM
path1 wrote:Interesting idea. I would lock the far end of the roller to relieve all tension.
I had same problem. Someone on here recommed, and it worked... inched back in using a fish hook and line. Pulled little by little after finding sweet spot of very little tension. Took awhile but was successful.
โOct-22-2019 09:01 PM
โOct-22-2019 08:28 PM
โOct-22-2019 07:45 PM
DFord wrote:
When you post your picture, only fill one of the size blanks. That works best for me. The other dimension will size itself and your picture won't be distorted like the one in your post. I usually use 600 or 800 for the picture width unless I want it smaller, then 200 works nicely.
You image is 278w x 370h pixels before being distorted but it's still blurred.
You won't be able to move that rubber bead back as long as the awning is under pressure.
โOct-22-2019 07:42 PM
Dutch_12078 wrote:
Go here and follow the directions...
http://photoposting.is-great.net/
โOct-22-2019 07:29 PM
โOct-22-2019 07:15 PM
