CarnationSailor's avatar
Sep 26, 2023
Window Problems
I have two problems with one of my windows. The window is the type that slides upward by releasing the catches at the top of the pane and pulling up on the lip (frame). First problem is that the lip (metal frame) is no longer attached to the glass, and pulling up just separates the frame from the glass. The frame has a u-shaped channel that the glass slips into, and there is a thin length of rubber that wraps over the top of the glass and then the u-channel slips over the rubber and the glass edge.
It doesn't look like any adhesive was used to attach the metal lip to the glass edge. (Maybe that's the cause of the problem.) Has anyone dealt with this problem before? Any suggestions as to what type of adhesive to use? I'm thinking I need to glue the rubber to the glass, and the metal to the rubber.
The second problem with the same window is that the bottom wiper-type seal has shrunken, resulting in a gap between the seal and the glass.
Here is a photo of the seal:
I want to replace the seal. Has anyone done this before? Is it difficult? Any tips?
Thanks
    Would you happen to know the brand of window you have? And ideally, the series number? Krino and Hehr (now both owned by Lippert) were common brands among the older campers.
    Also, what year is your camper?
    From the word description and the picture you posted, it is hard to understand the brand window you have. I have not yet seen an RV window like what you are describing where the glass is not bonded to the metal frame.
    The Krino and Hehr windows I have worked with seal (bonded) the glass to the metal frame. That seal creates the water seal of the glass to the frame. Then, there is a glazing bead of vinyl that inserts into a channel to keep dirt, etc, out of the frame channel. Felt often fills the gaps between the sliding metal frame on the lower section to the outer frame mounted in the wall.
    See these pics of a single-hung vertical slider window. Does yours look anything like this? Posting some pics of how the glass is mounted may help someone identify yours.
    The window out of the camper during a restoration.
    The upper frame fixed pane vinyl glazing bead
    The lower sliding pane vinyl
    It looks like this when installed in the camper
    I have used a product called "Parrbond" to seal up gaps in the glass to metal frame seal. This stuff https://www.amazon.com/RV-Motorhome-Joint-Crack-Repair/dp/B007HRX62S. You can shop for a better price, just freight can be as much as the tube of sealant.
    It will bond to glass and metal. Also, certain plastics and other materials. It is used to seal water-leaking gaps, not to bond the glass originally to the metal frame around the entire perimeter. It may work for that, but I have no experience using it that way.
    John
  • Look for rivets in the upper two corners of the frame that attach the upper frame to the two side pieces. All four sides of the frame should be attached to each other, either welded, rivets, etc.
  • Well, this seems to be a first for this forum. It seems no one has had a problem like this before as I have received no responses. Maybe someone will respond this time around.
  • joebedford wrote:
    Other photo
    Thanks for the help with the image link, but can someone show me how to change what I have in my original post so that the photos will appear there?
