Winegard Antenna
anchor
Want to add a Batwing? to our Winegard antenna. When in the down position it is against the AC shroud so the added wing would not fit. Want to change the down position. Do I change the down position from the roof or inside? Thanks
2002 Class C 31' Gulfstream
2005 36' Keystone Challenger 5er
2000 Chev 3500 1 ton crew cab dually
2014 Ford Fusion
Trawler and Sailing (Ocean & Gulf Cruisers)
Fulltimers
Present Hobby: Cameras
Residents: Florida Gulf Coast
14 REPLIES 14
anchor
Yes, it is Digital. Thanks
2014 Ford Fusion
Fulltimers
Chris_Bryant
That 19" Magnavox *is* a digital TV, isn't it?
-- Chris Bryant
anchor
Hi iagary
It is set on TV. Will check tomorrow or very soon on the other suggestions if we have that input on ours. Sure appreciation the help. We just brought it back to "storage".
Thanks
2014 Ford Fusion
Fulltimers
iagary
Also, is "input" or "source" on TV set on "TV"? Another of my mistakes!
iagary
I am sure you have thought of these, but is the selector/booster pushed in the "on" position? Have you run a channel scan? I only ask because I have made these mistakes.
anchor
Me again. Installed the Wingman. Do not get any picture at all. It is a 19" Magnavox. Tried the TV in the house and it worked. I feel it must be something I'm doing in setting it up. Need help!
2014 Ford Fusion
Fulltimers
Lynnmor
anchor wrote:
When installing the Winegard extension (Batwing?) can it be installed on either side??
It's called a Wingman, and no, it only installs one way.
anchor
2014 Ford Fusion
Fulltimers
RLS7201
Dutch_12078 wrote:
If your installation is similar to the photo shown, I would just rotate the base assembly far enough to the right to clear the Wingman past the A/C and reseal it.
X2. This is exactly what I did when I add my Wingman. Just reindex the whole antenna assemble a few degrees and reseal.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
wa8yxm
You have to turn the mounting plate (Roof) around.. So it's done from topside.
Or in many cases you can cut the end director element off the Wingman, Not as good as having all 3, but still better than not having it.
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
MrWizard
Moderator
Moderator
The dial on the ceiling is keyed to the down position
You flip sides on the roof
All you have to do is remember the front of the antenna now points out from the RV not in towards the RV , so the disk pointer is facing the back of the antenna not the front where you want to point the antenna, put a mark on the dial for the new front spot pointing
After a few outings to will have it down pat
You still line up the dial marks inside just the same as always to store it away
I can explain it to you.
1997 F53 Bounder 36s
Johno02
Ran into same problem on previous Motor Home. Several choices available. If Batwing is older model, try a newer model without the wingman. They were upgraded about 2005 or so. Install Sensar Pro Meter and booster inside to replace current power supply. Replace with a Jack instead. Replacing the head is easy, Just tw pins to pull and replace. The SensarPro booster is an exact-fit replacement, depending on where it is and how hard to get to. Easiest solution is the Jack as a replacement.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
IAMICHABOD
I had a clearance problem with the Wingman and I was told to change the position I had to remove it all and re-install backwards, which wasn't advised.
So I opted to put a Jack Antenna on.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
