RonWSl
Aug 23, 2013Explorer
Wiring Generator to Transfer Switch via Current Protector
I just purchased a Champion 4000/3500 (no Honda vs Yamaha vs Champion or quiet vs. too much noise please). In my 07 KC Montego Bay, I have gen prep which includes: front box to place gen in and what appears to be an Onan harness. I have a Lycht auto transfer switch and a Safeguard Generator Supplemental Over Current Protection box.
The RV already has the wire ran from the transfer switch to the Protection Box which is mounted in the rear of the metal front generator compartment where an onboard gen would set.
I want to wire in a 30 amp cord so that I don't have to use the rear corner 50 amp cord with an adapter plugged into the generator. Thought that I would run a shorter cord from the generator compartment to the Champion and leave it in the truck bed.
In popping off the cover to the Safeguard Protector, the wire coming from the transfer switch has: 1 red; 1 black; and 1 white wire. The red and black attach to the Protector and have 2 short capped Black leads/wires coming off of that. The white is just capped off and attaches to nothing.
The 30 amp wire I want to use only has 1 black and 1 white and 1 green wire. Obviously, the white goes to white.
First question, what do I do with the green (ground?).
Second question, which of the 2 black leads from the Safeguard do I wire the black cord wire to: either or both?
Searched but couldn't find an answer, and my RV electrician buddy is unavailable.
Thanks
Ron S
Thanks
Ron S
