โApr-11-2015 09:54 AM
โApr-13-2015 08:05 AM
โApr-12-2015 04:49 PM
Almot wrote:I would assume that the unbalanced excitation of free electrons morphs back into a balanced state when idling. If the bonds are weak or if the free electron is still "close" to the original structure, there probably is not a lot of energy dissipation going on.
West - if we don't collect electricity from excited electrons, they will come down to their previous low energy level. This difference of energy needs to go somewhere, in idling panel - heat, glow etc.
โApr-12-2015 03:24 PM
โApr-12-2015 01:50 PM
โApr-12-2015 11:25 AM
โApr-12-2015 10:38 AM
red31 wrote:
I object to the panel cooling, I'll suggest that some photon energy is removed/used so it doesn't heat as much.
Goggle
http://www.reddit.com/r/askscience/comments/ye346/when_you_complete_a_circuit_with_a_solar_panel_it/
โApr-12-2015 10:35 AM
โApr-12-2015 10:26 AM
tpi wrote:If there was ever a subject to which google was appropriate, this is it.
Could you point me to more info on the subject?
โApr-12-2015 10:14 AM
red31 wrote:
I like this answer
Now what do you do with the electron-hole pair:
- You can do nothing: It recombines, emitting infrared (which is absorbed and becomes heat in the panel)
- You can use it to drive an electron through the wiring: Some of the energy goes into the load, some in to the panel resistance, and some into the electron-hole anihalation when a returning electron falls into the hole (across a much lower energy gap).
โApr-12-2015 09:57 AM
red31 wrote:
So the panel should get hotter and hotter till ?
โApr-12-2015 07:29 AM
โApr-12-2015 07:25 AM
red31 wrote:
I thought current was electron 'movement'. What causes 'flow of current'?
โApr-12-2015 07:22 AM
โApr-12-2015 07:15 AM
red31 wrote:
What causes atoms to move?
