RoyB
Jun 25, 2013Explorer II
Cute little generator...
I see the running watts is 1600WATTs continuous so most definitely will not be able to run your air conditioner. I would also be suspect the 120VAc waveform may not be the most ideal for running your electronics. We are all used to seeing the outstanding waveform coming from the HondA EU2000i Inverter type generators like shown here.
This is probably a good one just to have around but may be a bit loud loud to use at regular camp sites.. Sure is a good price... Think I read it will use up one tank gas running at half load in just over 3 hours... It takes three hours to re-charge your batteries if you had a B&D VEC1093DBD 40AMP smart-mode charger plugged into to...
Roy Ken
Roy Ken
