BradTX wrote:
SoundGuy,
Now you've got me looking at surge protection and voltage regulation. Looking on the TRC site at the pdf for the 30 amp VRSG, it states I need surge protection before AND after the regulator. Is this overkill? It would seem the surge protector upstream of the VRSG would be protection enough. Am I missing something?
Brad:
My apologies for taking this discussion off your original generator topic. However, it seems to me that fully understanding how to best protect our trailers' electrical systems, regardless of
how we're powering it, is worth discussing. Yes, at first glance it would seem that double surge protectors is overkill, however there are good reasons for this when you look at the details. TRC's first recommended stage is a simple surge protector such as their basic model #44260 which really doesn't do much more than suppress surges, rated to 2100 joules / 6500 amps, and detect possible pedestal miswiring ... it has no ability to cut incoming power if it's either too low or too high, nor should it as the VR obviously can't do it's job if the incoming source has been disconnected. Logically one would think features emulating those offered by the #44260 would be built in to voltage regulators such as those offered by TRC and Hughes in order to prevent the VR from self destructing but apparently that's not the case. TRC's solution therefore is to recommend the #44260 be inserted in the line
before the VR for this purpose -
"The VRSG is not a protective device and the connected RV will not be protected from damage should an open neutral develop during the course of operation. The fault indicator panel is for indication only. Note: The VRSG is not a surge protector. To achieve the ultimate combination of line voltage and surge protection, use with Surge Guard models 44750 or 34730 which must be plugged in after (downstream) of the VRSG. In addition, to provide surge protection for the VRSG, use Surge Guard model 44260 which must be plugged in before (upstream) of the VRSG."However, neither the #44260 surge guard nor their #10176 VR have any ability to protect the RV's electrical system against other common line issues and for that TRC recommends using a fully featured surge protector such as their model #34830 (current version of the older 34730 which I own), inserted
after the VR.
Logically one would question why these manufacturers just don't simply combine all these features into one box, the answer I suspect being cost which would likely discourage many from making the investment in the first place. The second issue is that none of these devices should be considered a "one time, lasts forever purchase" - given a sufficient number of hits it
will eventually fail and
will require repair, a situation I suspect many consumers wouldn't understand or view favourably at all. It's one thing to replace a basic $100 surge protector, quite another to replace or repair a $1000 "all in one" box. As mentioned earlier I suspect that's why Progressive Industries offers a limited lifetime warranty on their hardwire EMS and has a program in place to offer replacement circuit boards that can be field installed by the user - it's just a clever way of dealing with components they
know will eventually fail and in this regard TRC may have really missed the boat. I'll know myself later when I call TRC to see if they'll sell me a replacement circuit board for the dead VR I currently have sitting on my workbench. ;)
