3 tons wrote:
So today at 93df ambient, and with inverter bypassed and entirely out of the campers VAC loop, I decided to run the air conditioner directly (via the main panel) from the Honda 2200i with it in the eco mode…Before starting, I first ran the air cond for about 40 minutes to be certain it was up to operating temp…Results??….. After a half dozen test the Honda started the air conditioner while in Eco every time….
FWIW, Before taking the inverter out of the loop, I had first tried by lowering the ProSine 2.0 (a pass-thru inverter) inverter’s cut-off voltage and Hz to Xantrex’s lowest allowable settings of 85v and 50h, but to no avail…The inverter apparently ‘sees’ this as a defective shore power scenario and disconnects from the genny… And this is where the genny to inverter oscillations begin… As previously mentioned, I do have a Soft-start…
Makes me kinda wonder, of these many folks who report that their generators will operate their air conditioners while in the eco mode - how many of these generators being used in conjunction with a Smart (I.e. power sensing) pass-thru type inverter??
This is just another reason why the outcomes of each case may have a different ending…
3 tons
We've discovered the Micro Air needs a very clean pure sine wave to operate properly. There are some inverters and inverter generators that will not operate properly with the Micro Air because they distort the waveform under load. It may be possible the Micro Air itself modifies the sine wave in a non-voltage way (during the critical inrush current phase) that disrupts the proper operation of some hybrid systems. It could be something innocuous as just changing the phase ever so slightly.
BTW, maybe I'm mistaken, but I believe you mentioned in an earlier post that you were having problems starting your Micro Air equipped 11k BTU a/c with your Honda EU2200. I found that surprising. Now that I understand the context, it makes more sense. Our Honda EU2200 will start/run our 11k BTU a/c without a Micro Air. We went ahead and installed the Micro Air anyhow just to reduce wear and tear on the Honda. 50-60a of inrush places a lot of electrical/mechanical stress on these smaller generators.
