- Chris_BryantExplorer IIA factoid that I am 90% sure of- the corrosion inhibitor used is sodium tetrachromate, which is a somewhat more benign brother to hexavalent chromium, also used for corrosion inhibition, and the Substance in the true Erin Brockovich story.
- Old-BiscuitExplorer IIIThe yellow residue doesn't smell.....it is the AMMONIA that smells
The yellow residue is dried up sodium chromate (rust inhibitor) and it is TOXIC
To clean it up use safety glasses, masks, gloves and vacuum it ---do NOT use air compressor to blow it out
Coolant solution is Ammonia, Hydrogen, Sodium Chromate and Water
(Some units have used Helium vs Hydrogen----very small percentage....Atwood HE and aftermarket replacements) - Grey_MountainExplorerOK. Thanks. I was getting confused over the smell from bad water - strong sulphur/rotten egg smell.
Thanks for the response. - MFLNomad IIYup...not sure how you'd forget that smell, but it will go away eventually.
Jerry - Dutch_12078Explorer IIStrong ammonia smell...
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
