mchero
May 05, 2014Explorer
Yet another Norcold recall issue
Had just purchased a coach with the Norcold side by side. Had the recall done BUT the module was tripped.
Did some testing & found that the cooling unit is indeed toast!
Ordered a NEW amish cooling unit from RVCOOLINGUNIT.COM
About 1250.00 with shippng. I want to be able to have a sound sleep at night NOT thinking about the Norcold!
Will keep this thread going as I get the hardware.
I tested the unit W/O stepping away from the coach. While on AC that chimney actually got CHERRY RED! Nothing cold in the freezer so I pulled BOTH plugs & disconnected the board.
I want to stress the fact that I did NOT leave the coach while that Norcold was plugged in!
Also, going thru the washer/dryer I found it CHUCK FULL of lint in the dryer hose. I pulled the unit & found the exhaust boot between the drum & the backside of the dryer PLUGGED as well.
I believe the use of dryer cloths is the reason the lint buildup!
I STRONGLY suggest users pull the washer/dryer every other year & inspect closely! Also replace BOTH hot & cold lines. Don't want them failing!
Will keep you all posted.
