Right. That system is for a fixed installation and 10 270 watt panels would take up a LOT of real estate. I'd be able to get two, maybe three on my trailer.
What are you looking to do with the solar. How much room do you have to mount panels. How many batteries do you have or plan to have. Most of all, what kind of loads do you run.
Since we know nothing of your needs, I can tell you how we use ours. We use a single 230w panel unmounted connected to a charge controller and then a battery bank. We are able to run the lights, fans, pump, and furnace as much as we want as long as we don't get too many cloudy days in a row.
Most times I can keep a inverter bank up too. We have used it for TV/DVD and other smaller items. With a large enough inverter we could run a hair dryer or warm stuff up in the microwave but we wont be cooking any turkeys in it.
BTW running the AC is doable but not practical.
So figure out your needs first, wants second and consider the limitations of room on the roof and battery bank. I bet they may be met for less than the system you were looking at.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
