2023 Super Duty 6.7PSD HO Review
FishOnOne
Here's a review from a Ram/Cummins fan on the 2023 Super Duty 6.7PSD HO. Don't agree with some of his analysis including it doesn't require cab off to replace the turbo. The 6.7 HO does have a couple of extra cooling lines for the turbo.
Enjoy...
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
46 REPLIES 46
FishOnOne
Looks like Ford quietly implemented a ninth injector for the regen process and now has a 15k mile OCI for the '23 Power Strokes.
FishOnOne
Cummins12V98 wrote:
My dad had a new 67 or 68 F100. Tires went VERY fast!!! He even tried wider front tires. The steering box was bad and it was replaced but no difference. I remember the front suspension being chained down and getting the hell bent out of it, still no better. Later in life I owned a 69 F100 Ranger and it drove like a dream with ZERO tire wear issues.
And todays Twin I Beam has "do not bend" casted into the I beam because of this practice. The twin I-Beam from a highway drivability standpoint is just not a good design and I'm surprised Ford still uses this design on their E Series vans and Super Duty's although they have been improved a little.
Huntindog
Cummins12V98 wrote:
Huntindog wrote:
Cummins12V98 wrote:
Telescoping wheel would be nice but for me in my RAM not really needed. No way on the heads up display, drove a Mercedes with it and hated it.
If I turned my steering wheel as much as he did I would be in the next lane as my steering is that tight.
Nice truck but not worth the $$$ IMHO.
Oil and fuel filter access is good but that hose monster is a "NO BUENO" for me. I will tale a couple minutes longer to change the filters for having my engine actually visible.
I have the HUD on my Silverado, and never want a truck without it.It was invented for fighter planes, so they could see what they needed to without looking down. best thing since sliced bread.
I get that but they keep making the info screen larger that you DO have to look at to change anything. I think a lot more can happen quickly in a Jet.
You have not seen me drive!!!!:B
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Groover
FishOnOne wrote:
larry barnhart wrote:
I believe every ford I owned wandered or drove. chevman
That was because of the Twin I-Beam suspension design. They were bad on tire wear too.
I had one F250 and 2 E350s with the Twin I Beam suspension. Drove all of them well over 100,000 miles. None ever wandered but I did need to get the toe-in adjusted on one of them due to tire wear. Otherwise they were maintenance free and had good tire life. Build dates were from 1991 to 2003. No diesels and no 4wd may have helped.
rjstractor
Agreed. I've owned and driven more Fords than I care to remember, and they all wander just a bit. It's not bad or dangerous, just a characteristic. Didn't matter what type of suspension either. I've owned or driven 2WD, 4WD, twin I beam, solid axle. I drove Ford shuttle vans when I was a teenager, and Ford ambulances and an F550 rescue truck in my career. Had an E450 motorhome that drove the same way. My current personal 2000 F250 and my work truck, a 2016 F150 both have the slight Ford wander. Dad's newer F350 has it too.
2017 VW Golf Alltrack
2000 Ford F250 7.3
Cummins12V98
Cummins12V98
FishOnOne wrote:
I suspect the 37" tall sidewall tires has something to do with that.
I am not so sure about that as I have the same tires on my 01 Sport. 33's I think and they are rock solid. They are a 80psi "E" tire I only inflate to around 45psi.
Huntindog
Huntindog
100% boondocking
FishOnOne
larry_barnhart
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
Learjet
Funny but true ๐Ÿ™‚
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
StirCrazy
Moderator
Moderator
Enjoy...
Link
I don't know why everyone thinks the new trucks are a cab off design like the 6.4 was..
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
FishOnOne
4x4ord wrote:
I've got a '23 high output on order but I'm currently hooked up to a 30,000 lb gooseneck and extremely impressed with the way my '22 handles it. Earlier today I was contemplating changing my order to the regular output.
If I was ordering one it definitely would be the HO
