2025 Cummins
FishOnOne
Looks like Cummins learned that the 2019 release had significant design problems.  Let's see if they finally fix them for 2025.
(6) Master Tech Breaks Down The Cummins Updates For 2025! - YouTube
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
1 REPLY 1
FishOnOne
So here's a quick look at the 2025 6.7 Cummins
Aluminum head
Back to cast iron block instead of CGI
New Water pump
CP4.2 pump
Oil filter cartridge cannister
2025 RAM HD Cummins Photos Leaked! Master Tech Breaks Down The Good And Bad Changes - YouTube
Looks like cummins can't standardize their engines for the long run like they used to.
