Wadcutter
May 18, 2009Nomad
ShapeShifter wrote:
Then you haven't seen mine.
Gee, ya think? Only how many million total RVs in the US?
I can't believe that my rig is the only one like this.
Since I most likely haven't seen your rig I don't know if yours is the only one like it or not. As I stated tho I have weighed a bunch of RVs and people were surprised when they found out they didn't weigh as much as they thought. If you've got the weight tickets then you know you've got a problem if you're over 20K.
However, if your rear axle is over 20K then you could have a problem if weighed more than you think. For example, let's say your rear axle weighs 23,000. The fine in IL for being 3000 lbs over is $165. If 3001 lbs it's $260. IL is cheap in that regard compared to some states. But the real problem would be after paying the fine. The fine is not a permit to move. The problem will be when forced to get legal weight before moving.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.203 PostsLatest Activity: Feb 28, 2025
