โNov-11-2007 07:40 PM
I have per the request of a few members, stickied this post. Please note, this is not a place to argue whether a law makes sense or not, just what the laws are. If you have a question about wt laws, that appears to be NOT answered in some way shape or form, please ask, and hopefully some of the ACTUAL weights and measures LEO's will answer, or those with some actual knowledge.
In the mean time, I do thank the OP for starting this thread, altho I have taken the liberty to change the title to one I think and hope will be a bit more informative in name.
marty
TV moderator
โMay-03-2008 06:11 PM
10Ton wrote:
As to the troopers being referred to as DOT. In many states there are Troopers, and then the Troopers that enforce Weights and FMCSR regs. On the door of the vehicles they drive will usually have Department of Transportation, and other info.
10Ton wrote:
Also, as impeccable as his credentials are, the claims that all troopers or DOT officers will always be correct on the law is false.
10Ton wrote:
Wadcutters other info is great, as well as the other LEO's however he is basing his info on IL regs and trying to convince all that the way IL does it regarding FMCSR regs applies nation wide.
10Ton wrote:
Others may add more items to check list in case I've left anything off, and remember, I reserve the right to be as wrong as anybody else.
jmramiller wrote:
I also am not sure what you mean by the Fed label. You stated that in Texas one could not register a truck for more than the Fed Label. If your use of the term Fed label applies to the manufactures sticker (GVWR/gawr) then your statement would be incorrect.
โMay-03-2008 07:14 AM
โMay-02-2008 02:50 PM
โApr-20-2008 05:28 PM
Wadcutter wrote:JIMNLIN wrote:
ok we've heard from a state dot officer [IL] on IL requirements,
I'm not and never was a "state dot officer". DOT is a completely different agency than the state police. DOT does not enforce weight laws, they do not do motor carrier inspections, nor do they have LE authority.
Truckers use DOT interchangeably with state police. 2 different agencies.JIMNLIN wrote:
your rated weight [GCVWR] which is your data plate lists as your ratings, what your axles are rated for, what your tires/wheels are rated for...and dot loves to look at all of this
your "tagged" weight which is what you have declared your ratings to be for tagging.
Don't confuse registered weight with axle and gross weights. 2 competely separate things and one is not related to the other. The only thing in common between the 2 is the word "weight" but neither law is related to the other. It's confusing for those not familar with the law. When they hear/read the word "weight" they don't understand the difference between registered weight limits and axle/gross weight limits. The OP was inquirying about axle/gross limits.
I've explained registered weights ad nauseum in the past too. Registered weight limits are really nothing more than a tax. In fact if you look at your state statute for registration fees it's likely that particular statute is titled something like "registration tax fees". You pay a certain amount of tax, ie registration fee, to haul a certain amount of weight. For example, if you want to haul 8000 lbs in your pickup then you pay the tax (registration fee) for 8000 lbs. But if you then haul 11,000 lbs in your pickup you would be subject to fine for overweight on registration, ie, didn't pay enough tax to haul 11,000. We use to do force registration in IL where if someone as described in the example was stopped then we could force the driver to purchase higher registration plates right there before he was allowed to move further. The increased registration cost was in addition to the fine. Now we just write the citation and if there's a record of additional such violations, particularly if company owned, then inspections can be done on the company and force increased registration.pupeperson wrote:
I wish you'd add to your comments the fact that equipment on our rigs that actually carry a DOT rating, like the tires and wheels, should not be loaded beyond those limits which actually are enforceable.
I didn't want to get into discussing motor carrier safety laws since they don't apply to the RVer. Commercial drivers should have received the MCS training. For a Troop to be certified to do MCS inspections is a 3 week class and involves a couple of very detailed tests. Weight laws aren't covered in that 3 weeks of MCS training as weight laws is a completely separate course that all Troops get in the academy. As a driver you know how extensive the MCS stuff gets. From front bumper to rear bumper and literally everything in between, including the driver and any passengers. When I was doing the full inspections it usually took about 45 minutes to do a complete inspection and that was if there wasn't any problems. I have done inspections where it took the entire shift to do the inspection on just 1 rig. If I were the drivers in those rigs I wouldn't have ever left the yard. Most of the time the drivers of those rigs were happy to help as they knew there were problems and had reported them but they were told to drive anyway or the company would get another driver. Find those kinds of things and the company gets a visit.
โApr-03-2008 07:58 PM
Mike Up wrote:
While the public at large is protected from commercial overweight trucks, looks like none commercial or recreational vehicles can cause harm to anyone on the public roadways from overload conditions without any legal protections for the public.
โMar-18-2008 09:24 PM
JetAonly wrote:
With out Hijacking the thread, how do the manufacturers decide what the GVWR is for a vehicle?
โMar-18-2008 04:38 AM
โMar-16-2008 01:28 PM
Mike Up wrote:
Sorry to bring this up a couple months after the fact. Here's what I got from the thread by policeman. Now I didn't read all as I have a severe headache.
โMar-16-2008 12:08 PM
โJan-28-2008 01:50 PM
โJan-12-2008 03:18 PM
โDec-16-2007 11:02 AM
โDec-07-2007 04:20 PM
โDec-06-2007 01:06 AM
โDec-05-2007 07:22 PM
pupeperson wrote:
Yes. That is correct, to a point. I believe it is unreasonable to list loads that cannot be carried at highway speeds. I also think it would be difficult to explain those precise nuances to most folks, including those who might give you a ticket for exceeding the weight rating molded on the tire sidewall. Increasing pressures above the listed maximum is normally limited to 5psi and 5mph and applies predominantly to ST rated tires
azcamping wrote:
"For all of those folks that want the OEM ratings to be law, how about going out and loading your pickup truck (that is the class of truck we are dealing with, right?) to a weight significantly over the door sticker. Then, go find..."
Uh, no.
I think the OEM ratings should at the very least be respected during the warranty period.
