specta wrote:
cummins2014 wrote:
I had a 64 Dodge Power Wagon that would do that , I'd be coming off a steep road in granny, and the transfer case would jump out of low range . It would be pretty exciting keeping it slowed down . :)
This is a first for me and I don't need that kind of excitement. LOL
I've still got lots to do before tackling the t-case.
It will definitely raise your heart rate , especially when you are on the brakes , and you start sliding sideways , so you let off , and then repeat , I came off a couple a bit faster then wanted . Or climbing and spin out , I got to when I’d lose momentum I’d let off throw it in reverse, and pop the clutch to catch me going backwards , that also raised the heart rate . Or spin out kill the engine , both feet on the brake , and sliding backwards, that was exciting .:)
