Mr_Usa
Jul 29, 2009Explorer
Show your mods!!
This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
Since this forum is not as active as a lot of the others - I just generally leave things pretty much alone unless I see a rule violation...
A Modification section would be good so:
I can make the Mod thread a "sticky",
OR
I can see if we can get a sub-category for Mods (would probably take some time to do this as it's a programming issue)
OR
we can just let the thread run - what's your pleasure???
One thing though - if we let it run and it gets large (and it probably will) - - you ALL have to promise - NO BUMPING - if someone bumps the thread after you promise me not to, I'll lock it down...
Also remember RV.Net maximum picture size is 640X480 pixels... I don't want to have to spend a lot of time editing picture sizes... If you don't know how to edit size, go to the Tech Forum and look at the stickies there or ask the Tech Forum Moderator for help - they will be glad to help you...
The "sticky" I could probably get done in a day or two as this does not require a programming change...
Please PM with your answers so we don't hijack this thread with your comments...
Les - Moderator - Hybrid Forum
