This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
2L Water Accumulator Tank Made from 4" PVC. Capped each end. Drilled and tapped schrader valve and 1/2" water line. Installed with cut-off valve on hot-water bypass (no red-pop will enter it). Total cost ~ $20 for the tank. Quiets pump operation. Runs longer, but less often.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.205 PostsLatest Activity: Mar 05, 2025
