โAug-29-2020 10:20 AM
โAug-31-2020 05:32 PM
โAug-31-2020 10:40 AM
โAug-30-2020 12:42 PM
โAug-30-2020 10:14 AM
โAug-30-2020 08:42 AM
โAug-30-2020 01:13 AM
โAug-29-2020 10:23 PM
โAug-29-2020 06:12 PM
Charles F Fisher wrote:
it is 2 wheel drive 400 trans. I may be leaning towards the cam. the engine has 102,000 it turned 100k while we had it. I really would like keeping it as stock as possible but I still need it to pull.
โAug-29-2020 02:58 PM
rjstractor wrote:
You could do both, but changing gear ratios would likely help a lot. If you are down to 30 mph it sounds like you are in first gear at the top of the hill. Lower gears might allow you to pull the hill in second to give you another 10-15 mph. But like was pointed out, you only have around 200 hp or so. If you change the gear ratio to 4.11 a GearVendors unit would give you about the same final drive ratio in overdrive as what you have now. It's a little spendy and like was mentioned previously doesn't work in 4WD.
โAug-29-2020 02:57 PM
โAug-29-2020 01:35 PM
We have a 1987 Coachman 5th wheel. We pull it with a 77 C20 Chevy Camper Special It has a 454 from the factory the rear is a 3.21 ratio our problem is long steep hills. We hit the bottom doing 65 and by the top we are at maybe 30. Do I change the rear to 4/11 or build up the engine. The truck is like new been in storage a long time with no rust and the camper is in the same condition.
โAug-29-2020 12:51 PM
โAug-29-2020 12:46 PM
โAug-29-2020 12:35 PM
Seon wrote:
Would an "Over and Under" gear box work?
https://www.gearvendors.com/index.html
