Need Toy Hauler with 15' garage or more, What to look for?
SpecRacer
Looking to purchase a toy hauler but need more garage space than I have been able to find. Not very familiar with all the different brands. Can someone give me some ideas of what company offers a larger garage area?
Tow vehicle is new Ford dually so "size doesn't matter"...
12 REPLIES 12
StirCrazy
Moderator
Moderator
Concidering it was 5 years ago that this was posted, I hope he would have found somthing long ago.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Seems to be a lot of these old threads popping up lately. Checking the date on the OP's post isn't the first thing I look for, so easy to get sucked in when it shows up on the "new"/"active" list of threads.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
Nomad III
Nomad III
Two thoughts:
 - Look at horse trailers with living space. 4 horses can easily weigh 5000lb, so it will be built to handle the weight.
 -Look at a motorhome pulling an enclosed trailer (check the tow ratings of the MH to make sure they are suitable).
The problem with a huge garage in  a monster 40ft 5er is you get the living space of a 20ft 5er when traveling (or you have to spend an hour loading/unloading for an overnight stop).
None of the options will be cheap.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
kellyo1180
We have looked for a toy hauler with a 16 foot garage to fit two Polaris sportsman 500 4 wheelers inside and camp with for the last four years. All we can find are heavy beasts that are not made well for all that weight. The few that are built well, are over $100,000 +. So we are looking at well made aluminum cargo trailers and custom ordering one to our design.  Triton, Cargo Pro, Aluma, Legend. โ€ฆ. We loved the Triton but they do not make a 7.5 wide with an extended tongue the dealer said.  We found a dealer who really helped us customize ours so we are working with Legend trailer dealer in Wisconsin.  We are designing a 7.5 wide x 7 high x 22 foot v nose all aluminum cargo trailer, the V nose Thunder series.  It will weigh about 4,600-6,000 lbs when built and loaded with toys and cargo. Holds 7,000 with dual tandem 3500 lb tortion axles and upgraded rims/tires to add more ground clearance. You can also upgrade to 7,000 lb tortion axles and frame upgrade to accommodate more weight. Going to insulate 1โ€ closed cell polyiso foam board in walls and 2 inches of same in ceiling.  We will build with furring strips and 2x2 framed cabinets and walls inside to accommodate a 36x36 shower, with 35 gallon grey tank, under the shower inside our under mount under frame.  A 35 gal fresh water tank, (no black tank on ours) but a composting or cassette toilet, small usb sink,  sleeping on either a Murphy style drop down or the happy jack style suspended beds on e track that fold down from ceiling. We added windows w screens that open,  Rv door and screen 36 w x 74 h,  a sxs escape door over the fender (44 wide. X 54 high) to accommodate a sxs for later on in life. There a larger OTF door options for sxs as well. Also adding 12 volt powered max fan ceiling vents in ceiling with covers, upgraded aluminum side vents.  We will also add a 110 electrical package and 12 volt power package. European dome lights for interior lighting, luggage rack or ladder racks on roof to mount solar panels to later, we will have a 110  mini split installed for quiet, efficient heat and AC that can run on on solar or run on an inverter generator. An 18 foot awning,  power tongue jack, extended tongue for safer maneuverability and allow room to build either a dual propane tank holder or expanded battery bank for solar over time. We requested all supports 16 on center , roof, walls and floors. 30x30 windows and 15 x 30 horizontal or verticals that open with screens, lots of options to choose from. The ideas on Facebook cargo trailer toy hauler conversion groups are endless. We mostly remote camp in national forests , bml land, state forests and adventure off road atv trails so we want enough choices for power to remote camp for days if we want.  Outdoor portable shower innovations are available too if you are camping seasonally as well.  Many campgrounds come with shower houses.  We  prefer our own shower. Happy camping.  The MN Olsons.
Rustycamperpant
KZ Venom fifth wheelers have up to an 18' garage. Check them out here : https://www.kz-rv.com/products/venom-v-series-fifth-wheel-toy-haulers/ These are VERY nice.
2009 Ford Expedition EB, 3.73, Equal-i-zer
2015 KZ Sportsman Showstopper 301BH
Lwiddis
Iโ€™d vote for the half bath model...for me. So would the DW.
Daryl_B
Raptor 415 (15')
Jayco Seismic 3815 (15')
Grand Design Momentum 398M (18')
2022 F-450
2019 Arctic Fox 1140 WB
Past Rigs
2006 F-450 16k GVWR, Kelderman 4-link rear suspension
2009 AF 990
2016 EC 1165
2017 AF 990
smarty
Make sure you carefully review the carrying capacity of the toy hauler you select. We found instances where if you hauled anything in the garage the rest of the rig had to essentially be completely empty.
FrankoToo
Heartland has a Cyclone with 15 ft. garage style and also a 20 ft. open style. Size may not matter, the question is can your wallet handle the price:).
FrankoToo
2018 Cruiser Stryker ST2313
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
jbc28
We love our Momentum 381. It has a 15' garage and a half bath.
2018 F450 Lariat Ultimate
2019 Momentum 381M
TWZMYJP
Our Keystone Carbon 387 had a 17' deep garage
We used it to haul around our Wrangler JK Unlimited with a 4" lift and 38" tires...
Mod Edit: Adjusted photo width to 800x so as not to skew the forum.
'18 Jayco Alante 31R
lincster
Do you have to have a garage?
I think only a few models have a garage over 15'.
You may have to go a non garage model
Nice tow rig. I have the same and I can't feel my 17,000lb trailer behind me. Awesome.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
