Go big or go home! LOL! Seriously that is one beautiful trailer!
As noted, that's a lot trailer for a 1500 truck, but the weight is only the beginning. If you're average campers, you'll add 1200-1500 lbs of stuff in a trailer that size, so you'll be up to 10,000 lbs easily.
10% is the absolute minimum you want for hitch weight to have a stable tow, and that's about what they are quoting for hitch weight here (844/8496=9.9%). Note that mfrs are starting to get smart about making their trailers "half ton towable" by using axle placement to manage hitch weight. If you look at the floorplan, you have lots of storage in the bunk and kitchen areas, which are behind the axle. The danger that creates is that every pound loaded rear of the trailer axles decreases hitch weight, so you could actually wind up with
less than 10% hitch weight after the trailer is loaded.
Why this matters is that this trailer is 37' long!!! That's a BIG sail area to catch the wind and without enough hitch weight you won't be able to go more than 35 mph.
Bkuhl1179 wrote:
....but if itโs super windy I wouldnโt tow that day.
Nice thought, but we don't control the weather. Say it's checkout day at the campground, you have to leave by noon because someone else has that site booked tonight....you don't have the option of just waiting until the wind dies down.
The coil spring suspension on the 1500 doesn't do a good job resisting sway and roll on big trailers like this. Most think of going to a 2500 to get the 6.4 or Cummins, but it's really about bigger brakes and stiffer suspension...the 5.7 is a strong motor and with 3.90 gears power isn't going to be your biggest issue.
Even with a heavier truck, I would strongly encourage you to consider one of the two hitches on the market that uses the 4-bar linkage, either the Hensley Arrow or ProPride. These hitch designs use geometry to eliminate sway and enable smooth sway-free towing for very long trailers, even if you are borderline on the hitch weight.
Also consider how you plan to travel...if you are going an hour away to stay week at the lake a few times a season, you'll be OK with your truck. If you plan to actually travel with the trailer, towing will not become an exhausting experience.
Note that most if not all state parks will be inaccessible with a trailer that long. You will limited to campgrounds that advertise "big rig friendly". Our trailer was 35' so we lived with that for many years.
As nice of a trailer as this is, I would encourage you to start smaller.
