rgolding
May 29, 2013Explorer
Thank you for the replies and you were both right on the money. I saw your replies after I had got the problem fixed. I suspected a short, but I did not know about the second breaker. Please read below.
The plot thickens -
I really thought it was the thing I was calling a "12 volt single isolator rectifier" and that's what I went to bed thinking last night. My objective this morning was to remove the circuit unit from the circuit by putting the 12 volt battery positive wires on the same post. Turned power on, same thunk. That's it, I'm done.
Off to Bourbon RV in Bourbon, Missouri on I-44 for some help. At first they were puzzled, but what "Steve the Technician" knew that I didn't is that there were two of these circuit breakers. I was looking at the wrong one. They are very close to each other on either side of the front frame. The second one is hidden in a receptacle box on the back side of the same frame member. With tripping and resetting it was the source of the "thunk" and hot from being exercised. Determination was a short between there and the panel. He began feeling along the under skirt and found a place where positive wire was pinched between frame and plywood floor. Slit under skirt, pride wire out from between frame and plywood floor, repaired worn spot by insulating with tape, and replaced "thunking" breaker with new one, because it had been exercised so much, and I kept old one as a spare, plus a secondary new one. Seems to have been a problem waiting to happen since construction in late 2009 or early 2010 and finally wore through after about 15,000 miles. Not related to rain storm or any thing else, just time and wear and eventually a short against the steel frame.
So I've still got questions about the "Shortstop 12v s34 40A" circuit breaker.
Does it allow current to flow both directions?
Or is it just one directional?
What is the reason they are in the lines other than protection?
Just as a circuit protector or to prevent back flow of electricity?
Does it allow trailer battery to be charged by the towing vehicle? That has always been my assumption, but now a reason for more investigation.
Thoughts or opinions?
By the way, did I say the guys and gals at Bourbon RV in Bourbon, Mo. on I-44 are good? You bet they are!
The plot thickens -
44,056 PostsLatest Activity: Nov 19, 2013
