kt0819
Jun 28, 2013Explorer
2 more newbie questions
Thank you all for your help with my last electrical/wiring question. It was the fuse at the battery box that blew. We had a mobile tech come out (to fix the leak on the TT- on the dealer's dime) and he helped us troubleshoot and taught us a bit more about TT wiring. He put in a 40amp fuse and said that would keep it from blowing again.
However tonight when we were towing to our storage location we noticed that the TT outside running lights were not on. The brake lights came on when the brakes were applied, but no running lights of any kind. The TT is connected to the 2012 Yukon XL via a 7 pin connector. Could really use some insight as to why there were no lights on the TT and how to get them to go on. :) This, yet again, was not something mentioned in our PDI. :S
Also, our TT comes with a black tank flush. From what I have read, when dumping, we keep all valves closed. Hook up hoses, open black tank valve. Do we close the black tank valve before we open up the grey or do we leave it open? So after we've done the black tank, we drain the grey to clear out the hoses. After this, we will use the black tank flush to clean things out. Do most dump stations have a water supply?(we've never used any sort of TT before so dump stations are a bit of a mystery at the moment- never hung out at one before).
From my reading here we are supposed to use a back flow preventer and have a separate hose for this purpose- correct? My question is, if my procedure so far is correct- how long does this separate hose need to be? We currently have a 50ft potable water hose, a 20ft potable hose. We will need to go and get a grey water hose. Is a 25ft hose sufficient for this?
Dh won't be building a storage compartment for the sewer hose this year so we will just be using a rubbermaid set aside for that use only. Can we keep the grey water hose with the sewer hose or would it go with the fresh water hoses? Neither seems like an ideal solution for some reason but there has to be a right answer, right?
I figure this will all come together once we try it (we have yet to use the black tank at all and have only put in maybe a gallon of water into the grey) but I like to be as informed as I can.
Thanks!!
Thanks!!
